New Engine "Jalv": LV2 plugins as standalone layers
Great news, @zynthianers!
I’ve been working in a new engine that allows to launch LV2-plugins as standalone layers. For doing that, i’ve used (and extended!) Jalv, from David Robillard, one of the creators of LV2 plugin specification. In his words:
“Jalv is a simple but fully featured LV2 host for Jack. It runs LV2 plugins and exposes their ports as Jack ports, essentially making any LV2 plugin function as a Jack application.”
You could think …  “OK, but we already have MOD-UI that allows to load any LV2 plugin and combine with other plugins in any way we want …”
Yes, you are right, MOD-UI is fantastic, really! But is not a 100% zynthianic animal and some functionality is missing in the MOD-UI layer (and it’s not easy to implement!). In fact, only one MOD-UI layer is allowed in Zynthian, and no MIDI channel assignment is possible, nor cloning or transposing. You have to hardcode all this behaviour in your pedalboard using the MOD-UI web interface. Not a big problem …
But sometimes you only want to have Dexed, Noizemak3r, MDA ePiano or any other LV2-plugin working as “normal engine” in a layer, that can be transposed, cloned or assigned to the MIDI channel you want. And this is what Jalv engine allows. And it’s a small-but-huge step for Zynthian 😉
You can run any LV2-plugin inside a normal layer. Everything works normally in Jalv layers. All functionality is available:
  • MIDI Learning
  • Transpose
  • Clone
  • Audio-Routing to MOD-UI
  • Move to a different MIDI channel
As the list of LV2-plugins installed in the system is quite long, we don’t want to have a huge list of engines in the Zynthian UI’s Engine Selection Screen . We would like to decide what LV2-plugins are enabled for the Jalv Engine. So … our beloved developer @mheidt has created a webconf-tool for choosing the plugins we want to enable. Thanks a lot, @mheidt!!  😉
Finally, this is the list of default plugins that you will see in the Engine Selection Screen prior to choosing your own list:
  • Dexed
  • Helm
  • MDA ePiano
  • MDA Piano
  • MDA DX10
  • MDA JX10
  • Noize Mak3r
  • OBXD
  • SynthV1
For enjoying the new Jalv engine, just update your Zynthian software. If you don’t remember how to do it, read the Wiki!! 😉
If you don’t have a ZynthianBox, perhaps you should think about building one 😉
References:
Subscribe
Notify of
guest
0 Comments
Oldest
Newest
